EST3 aka XLS1000, ADT 3000
The Honeywell XLS1000 is the EST3.
Also ADT system 3000 is a EST3 100%
It seems like the XLS1000 is sold overseas, China and India
The XLS200 is a 500 point version.
http://www.honeywell.com.pl/pdf/automat ... 0770R3.pdf
https://buildingsolutions.honeywell.com ... ourse=1048
http://www.diysecurityforum.com/index.p ... .msg101610
FVILLA
Re: EST3 aka XLS1000, ADT 3000
Post by FVILLA »
Hi, also the certification is basic the same as the GE EST3, but the software and key is different.
see the mail from tech support:
Hello,
I’m not familiar with the EST3 Certification, but I think the basic content is the same. The main idea is to gain some experience using the SDU by programming and installing hardware in both, a single panel and a network.
The main difference would be the use of the 3-AADC in our labs for interfacing with System Sensor detectors.
You will need a Honeywell SDU key which I think it has some special coding that only works for Signature devices manufactured for Honeywell.
Let me know if you have any questions.
Regards,
Michael Carone
Specialist Tech. Training Sr.
Honeywell Building Solutions
372 Hefferon Dr.
St. Augustine, FL 32084
akrajib143
Post by akrajib143 »
[Hi, also the certification is basic the same as the GE EST3, but the software and key is different.
Hello,
Regards,
Michael Carone
372 Hefferon Dr.
St. Augustine, FL 32084]
I have XLS-1000 SDU software dongle. EST 3 Module Supported with XLS-1000 by SDU but Detector SIGA-PS/HRS not Supporting.
Detector Showing Detector Compatibility Fault. How can I solve this issue?
Please help me.
Enamul
for some reason modules always seem to work but the devices/smoke do not
if you have a XLS-1000 you will need compatible smokes not siga-ps
ebay XLS-PS
akrajib143
[for some reason modules always seem to work but the devices/smoke do not
ebay XLS-PS]
Do you send the latest compatible detector list of XLS-1000??
Thanking You,
Enamul
ncityu
Post by ncityu »
I can solve the compatibility problem between SIGA-PS and XLS-PS. I need to do some technical processing to make EST3 compatible with XLS-PS, and also make XLS1000 compatible with SIGA-PS.
akrajib143
[I can solve the compatibility problem between SIGA-PS and XLS-PS. I need to do some technical processing to make EST3 compatible with XLS-PS, and also make XLS1000 compatible with SIGA-PS.]
Hi Ncityu,
How is it possible?
Please help me regarding this issues.
Thanks in Advance.
EST5
Post by EST5 »
maybe EST will issue new 3-DSDC micro to fix XLS-PS not working on Edwards EST3 System.
akrajib143
ncityu wrote:I can solve the compatibility problem between SIGA-PS and XLS-PS. I need to do some technical processing to make EST3 compatible with XLS-PS, and also make XLS1000 compatible with SIGA-PS.
Bro,
Please help me regarding this issue.
I am in huge problem. XLS-PS is not available here. But Siga-ps available here.
Please help me.
E-mail: engr.ekabir@gmail.com
